Trailer light hook up isn't working
Baton Rouge, Louisiana
im in the process of re wiring a trailer and the hook up to the trailer on my 96, I'm getting 12volts to every wire except the yellow one. I got my multi meter out and tested it at this little black box. Could that box be the reason it's not getting any voltage?
The oem black boxes are notorious for failing. I replaced mine with a uhaul one, worked flawlessly. Or go to Walmart.
Uhaul definitely will, they install hitches. The truck I got it from was installed by uhaul. Theirs are high quality and wires are labeled nicely. Should be given its their business. If you have any questions let me know and I can get a couple pics.
Some pics would be nice if it isn't a problem and do you know how much it would cost
Recently installed that Hopkins kit on my 97 lx450 and it worked as advertised and mated to the factory plugs perfectly
I need to do this, rented a uhaul the other week and had running lights but no brake or turn lights. The PO installed something with cheep crimp connections..
Have seen 3 or 4 different versions of trailer light conversions that appear to be OEM or port/dealer installed. Mine died due to heat from exhaust. Found another one in a parts rig and it works OK.
Sorry for the hijack, but my trailer lights weren't working so I soldered on a new converter and hooked it up with everything working except blinkers which was good enough at the time, but now it stopped working again just a week or two later. Everything gets 12 volts until any laod is put on, then it drops to about 3 volts. My right brakelight also only works sometimes. I'm not sure what the problem is.
Here's something new that might work for all these bizarre trailer wire problems.
Tekonsha now makes a trailer wiring connector that is "zero-contact":
Tekonsha® Zero Contact Interface Trailer Light Power Module
It has sensors that clamp on to your vehicle wiring without any splicing.
Trailer lighting takes power direct from your battery, not the Cruiser harness.
I don't have one yet, but I'm leaning towards getting one.
Got a new product email from Del City about it. Tekonsha stuff has worked well for me in the past.
