First off: yes I searched.
Yesterday I installed a trailer brake controller. The controller is a 4 wire unit- power, ground, brake trigger, and signal out to the trailer. I ran power straight from the battery with 12 gauge wire through a 20 amp fuse. I'm grounded at the left kick panel ground location, I'm running 12 gauge wire back from the controller to the trailer plug, and I spliced into the green and white wire just behind the brake switch (it's only hot when the brake is pushed). I've also noticed that when I push the brake button on the brake controller my rear tail lights come on.
After doing the install I noticed that as I was sitting at stop light I was only idling at around 350 to 400 rpm (I'm not sure if this has anything to do with the brakes I think it's just a coincidence).
While driving at about 1500 rpms I pressed the brake button the controller I noticed that the engine when up to about 1700 rpms. The transmission did not down shift- I think it's unlocking the torque converter.
When using the cruise control I pushed the brake button on the controller it shut the cruise off. I'm guessing this is because the brake lights are triggered.
So, does this all sound normal and ok? I'm driving to southern Nevada tomorrow (about a 12 hour drive) and I'd like to fix any problems before I leave if possible.
