I replaced my birfields and axles with the trail gear ones here about a month ago. Reason being was I had clicking after I rebuilt the front axle and my driver side seal failed(groove in axle). So I've noticed on full lock left hand turns I have noticable clicking on driver's side, not as loud as before (swapped axles when rebuilt 1st time passengers side clicked) and I haven't tried it in low range and it's only at full lock. My birfields came prepacked with some orange grease some came out when I put the axle shafts in but I got it back in there. So since mine are gun drilled I was wondering how many pumps of grease it would take just to see if that would even help? I also noticed my spindle on the driver's side had a noticable groove down near the base where the inner bearing would ride I'm assuming. So could it be more possible that is my noise and not my new axles? Wheel bearings are all new as of like 6-7 months ago.
I'd try greasing them with a good moly grease just for fun.
Then put it in low range and turn to full lock. My stockers are worn out and I get 0 noise in hi range with the CDL unlocked but in low range they make all kinds of racket and I can feel them clicking and jerking.
I have the same birfields sitting on the shelf waiting to be installed so I'm curious to read the responses.
I have some Valvoline grease that says it has moly in it. I've been using it for the knuckles and birfs. I bought alot of it since I've done it about three times now...
So to answer my original question and to help others. I pumped a half tube of moly grease into the zerk fitting and could see it moving around inside the knuckle through the knuckle fill hole. I ended up putting 3/4 of a tube each into both zerk fittings and the rest into each of the knuckles plug fill hole
Yeah I had the knuckle cavities 3/4 full when I rebuilt. Yes my wheel bearings are still tight. I actually tightened my wheel bearings to like 42ftlbs the last time I was in there. And my driver side inner axle seal let go what seems like last week so when I go back in to do the seal before winter I'm going to set my bearings to 30ftlbs on both sides. May also need to replace my spindles since at least my driver's side had a pretty good groove in it from what I believe is the inner bearing seal. I don't remember what the passenger side looked like.
