Tracking down RF interference
When there is static on the FM radio, there is also so much RF interference to the garage door opener that the transmitter doesn't work. This was the same in the original occurance as it is in this recent occurance.
There must be some sort of way to detect what is throwing the RF and locate it.
I don't know of a RF detector per se, but have you talked to someone at a local Radio Shack about your problem? They might be of some help. Don't talk to one of their flunky saleman, ask to talk with a tech or a manger. Be sure to tell them all the details. One other suggestion: Contact the manufacturer of your door opener. If they have a tech support line or FAQ on line, use them as a resource. Maybe someone else has seen something like this. The more sources you contact, the better your chances will be of identifying the source of the problem. It's really a "Twilight Zone" type of problem! Good luck!
I was having this exact same problem last week. Starting on Thursday-ish, I started having engine-rev matched buzzing on about half of the FM band. Turning the ignition to ACC and everything was perfect. At the same time, my garage-door opener stopped working. Honestly, I wasn't smart enough to correlate the garage-door opener issue until I read this thread (I just thought it was dead batteries). My setup is completely OEM.
Then yesterday (Tuesday), everything went back to normal. Radio is fine and garage-door opens on every click.
If anyone else has seen this and has any troubleshooting ideas that are not mentioned already in this thread, please post it up. I was already planning to spend my Christmas vacation tearing apart my radio before the magic recovery.
check your grounds and also your alt might be dieing . one way you can check the alt is it eather take off the belts or unplug the harness to it ( now that I think of it :hhmm:you maybe able to pull a fuse got to look at the EWD or the FSM )
This problem just "went away" all on it's own. Haven't had it happen in a while. IIRC, it was happening after a big rain. I am wondering if water got in somewhere and it just took several days to dry out.
Not much help on this. It's still a mystery.
I just started picking up some RF interference also - kind of a ticking sound that is roughly correlated to RPM. This past weekend I relocated my washer bottle (which involves extending the wires to it as well) and removed the PAIR valve resonator. Doesn't seem like either of those should have an effect??
FWIW, plug wires, distributor cap & rotor were replaced about 2.5 years/20K miles ago.
Wow, that is a mystery.
There are many websites that deal with RFI, do a search.
If this recurs, you might follow the advice given here about disconnecting the alternator. That will confirm or eliminate it as the source of the problem.
In general there are two main sources of RFI from most cars, caused by either the alternator or the secondary circuit of the engine ignition system (the distributor cap and plug wires). The former will cause a high-pitched whine, the latter is more a lower-pitched buzz. Both increase with engine RPM.
If the alternator is the culprit, often simply a capacitor added between the output and ground will take care of the problem.
Often the RFI can enter the radio via the power supply. In this case, the cure is usually a choke added inline to the power supply line.
I've pinpointed the source by using an independent battery source to power the radio while running the car. I take a battery inside the car, and using a very short power lead (to minimize pickup of RFI through the power input line, which can act as an antenna for the RFI), power up the radio and see if the RFI has changed.
RFI can also come in through the antenna on a CB, ham radio, or FM broadcast receiver. It's easier to test the power line as the entry point, so do that first. If doing so makes no difference, it's coming in through the antenna.
There can be other sources of RFI on the car besides the two major ones. I've seen blower motors that were very noisy. I had some RFI from an FJ60 carb cooling fan once. It's also possible that some of the electronics onboard have gone a little wacky, especially when moisture is involved. Those are much more difficult to track down.
What was the nature of the RFI that you heard on the radio? like a sparkplug buzz, or like an alternator whine, or more like a bunch of background "hash"?
On my diesel, I've got no spark plugs, but I do get some minor RFI on the CB, it turns out that it comes from my auxiliary fuel pump (Walbro pump) located in the rear of the truck. when the engine is off, there is zero noise until I switch on the pump, then the "hash" begins. It's not something I need to fix, because it's only audible when the noise-blanker switch on the CB is turned off, so I leave it on.
Mine is literally a ticking sound - I'd guess about 3 to 10 hz
