Tracking down RF interference
TEXAS !!!
Had this happen once before and it "went away" after a couple of weeks.
I am getting radio frequency interference from the truck and it is related to engine speed. All sorts of static coming through on the FM radio and it interferes with the garage door opener. Stop the motor, problem gone.
How do I go about tracking this down and fixing it ? Is there some sort of equipment a good shop could use to pinpoint the source ?
TIA
R.
TIA
R.
How old are your plug wires? Here's a interesting read:
Truth About Ignition Wire Conductors
Bad plug wires can also cause performance problems. HTH
Plug wires are about 100k miles old. I replaced them at 110k and now have 206k mi. on it. How can we test them if, as the article states, the resistance of the wire is not an indication?
Much appreciated,
R.
Much appreciated,
R.
It would seem to me, that it's possible that the plug wires could be the source of the noise given the mileage on them and also that you live in Texas, which can get hot in summer (100F+). I would do close inspection to see if possible arcing from plug wires to metal surface is happening. How's the performance of your rig? As far as
testing the wiring goes, a good tune up shop might have the (expen$ive) equipment to verify plug wires, but you might be money ahead just to replace with good quality (not racing or high performance) plug wires considering mileage & environment. One last thought, if you have a shop that you can trust, it might be worth just talking to a mechanic about your problem before spending any more time/$. I am a computer tech, by trade, not an auto mechanic, so I understand electronics. From your symptoms, I would be looking at plug wires first.
Truck runs and drives great. Did a full tune-up about 12k mi. ago (plugs, cap, rotor, O2 sensors). Plug wires are about the only thing I haven't replaced in a while. I think new wires are probably about $100 or $125 from CDan.
That's a chunk of change. Get a second opinion before forking it over. Maybe Cdan could help.
Well it isn't the plug wires. Replaced those ($101 including tax at local dealer with 20% TLCA discount), checked to make sure the spark plugs were seated and that there wasn't any oil or liquid in the plug galleys. Still have the FM interference.
Any other ideas fellas?
I recently noticed that I have FM interference when my cell phone is plugged into the charger. I almost never have the radio on so I couldn't figure out what the problem was at first. Then one day I had the radio on and everything was fine. I plugged in my cell phone and there was interference. Unplugged it and no interference.
I'm sure this isn't normal, but I'm not really motivated to track down the problem.
Stock Toyota radio. Been in the car for a while. I did replace the original with another Toyota. I had the same problem while the original was installed, and then, it magically disappeared after a couple of weeks. That was a year or so ago. Problem just reappeared out of the blue.
Yes, we once had FM interference with the cell phone charger plugged in too. Might have been a cheap charger. No charger plugged in now.
I might check to see if somehow we have moisture in the dizzy. After that, I am running out of thoughts.
Distributor is dry indide and looks good. Could a faulty coil cause this? What about the alternator? What other parts are turning and are electrical and coud generate radio frequency interference?
Help me brainstorm this one.
TIA.
R.
My stock radio did this for a year and I went aftermarket and bypassed all the amplifiers in the system. No problems after that. Likely one of your amps...That stock equipment radio is getting old you know ????
This is not a radio problem. There is so much RF interference that it is blocking out the garage door opener ! You cannot hit the transmitter from inside the car and open the garage. Either you have to stop the engine, or you have to reach out of the car and hit the transmitter.
Something is sending out lots of RF.
Thanks for the ideas ! Keep 'em coming !
No noise with CDs. New battery in the garage door opener transmitter. Same problem when using a second transmitter. There is definitely RF coming from the car and it is related to engine speed.
Back here, did you have same problem with garage door opener?
I'm trying to find a pattern here. It could be a component in your ignition that's causing the RF interference and it also might be a combination of things. If it is a part on your truck that's intermittently going bad like this it's going to be 1. tough to isolate and 2. Expensive if you have to keep throwing parts at it like you've already done with the plug wires. Anyway, just trying to help.
When there is static on the FM radio, there is also so much RF interference to the garage door opener that the transmitter doesn't work. This was the same in the original occurance as it is in this recent occurance.
I didn't mind buying new plug wires since they seemed a reasonable explaination and they had 100k mi. on them anyway. I tend to replace then on that interval regardless, so no big loss on that one.
There must be some sort of way to detect what is throwing the RF and locate it.
OK, this is totally maddening. All the interference just went away, magically, by itself. Radio now works perfectly and the garagedoor opens with every click of the transmitter.
Last night after replacing the sparkplug leads and coil lead, there was interference, this afternoon, without changing anything, while driving, the interference disappears.
The mystery continues.
