tracking down battery drain
ok got a new battery in one (of two that are buggered) of the cars, tested current between -ve terminal on the battery, and the negative wire going to the battery, started pulling fuses to find the drain on the battery
there is a 0.1 milliamp drain in the taillight circuit
the hard wire circuit that keeps the cd player memory and clock etc draws over 200 milliamps, but that fluctuates down to 4-5 milliamps at times.
i don't know what current draw is alright for automotive sources, is 200 milliamps too high?
is the .1 milliamp draw a huge problem (i.e. could it be causing the battery drain in less than a day?)
I'm no expert, but 200 milli amps does seem high to me. It also doesn't seem like enough to kill a battery in a day. I had a problem in a pickup truck where a 240 milliamp load killed a battery in a week, but it was fine for a couple days, at least.
well in this truck (i got 2 with electrical gremlins so repost that :flipoff2: :)) the battery dies once unexpectedly, gets fully charged, then runs fine for about a month, then loses charge suddenly again. (recharging via alternator, then charge tested with volt meter)
Don't forget to pull the alternator lead. My MG had this issue and the alternator was killing my battery. Could be a bad diode pack or windings?
