tracking down a short?
every couple of days my 76 40 is blowing the fuse that fuses the dash lights, parking lights, and tail lights... any advice on finding the problem?
My 71 did that. Tracked it down with a multimeter, and it was the contacts in the connector to the light switch, which had corroded and caused high resistance resulting in high draw and blown fuses. A mini-file on the contacts fixed the problem.
Are you running factory goods or aftermarket?
My '74 had trashed out tailights when I got it so I replaced them with aftermarket units that could be mounted up high away from rock danger. I had the same problem blowing fuses the first few times I drove it because the bulbs were a larger draw than the stock little bulbs. I upgraded the fuse to handle the added amperage and problem solved. I haven't needed to change that fuse for many years now.
stock lights... don't tell me this is going to be hard :( new i got off too lightly replacing the driveshaft uni joint (the bearing caps fell out after i removed the C clips, which came out with one twist of the screwdriver)
mine was shorted at the license plate light wiring where it went through the body..
didn't even think of the license plate holder
thnx
