TPS code and sensor
Boise ID
Going through all of the sensors and ran the diagnostics on my 93 1fz-fe and it tripped the code 41 which I believe it to be the TPS sensor.
Got a new one from toyota and put it on tonight and it didnt do what I wished it would do. I did unplug the battery to clear the ECU so hoping after 10 starts it will run better.
I am asking is there anything else to look at when that code comes up? I was thinking there might be something else that could also be a problem.
0) OBDI code 41 really does seem to be exclusively TPS related. How did you pull it anyway; paperclip method even though the CEL wasn't flashing, or...?
1) You're wanted in your other current thread.
2) You really should just run with one of your threads concerning this issue, say maybe this one:
https://forum.ih8mud.com/80-series-tech/226340-st-st-stuttering.html
rather than starting a new one with each new thought on the matter.
Better for you and for the rest of us in the long run.
Hang in there,
Curtis
I got a couple of them out there but was wanting this one more on the TPS rather then what could cause the stuttering. figured this would be more concentrated on all issues that are related with the TPS rather then somebody telling me again to go and check the air tube into the intake.
The CEL light was not flashing and it pulled the code 41 for the TPS. I know it takes about 10 starts to get the computer dialed in and got bored on about 5 or 6 and went to eat some dinner. All of the starts it ran exactly the same way as it did before I replaced the sensor.
Is there a spot were those wires can get burned under the intake?
1) Pull the EFI fuse to get the 'puter to reset itself. (Edit: Nevermind; unplugging the battery accomplishes the same thing.)
2) You've seen the threads about the (93-97) wire harness issue near the EGR system?
Oh, and for code 41: You should really check the FSM for your year, but my 91 manual says: TPS, TPS circuit, or ECU.
Curtis
Not sure which wires you are talking about. If you mean the main engine wiring harness, it runs on top of the valve cover, and passes next to the EGR right as it gets to the firewall. That is where most have failed. We have had a few that have failed as the harness enters into the passenger compartment on the US PS. Look behind the glove box.
Since many of us haven't seen your other threads and you plan to stay with this one, then you'll need to bring us up to speed on what issues you are having and what you have eliminated and/or replaced.
-B-
I am thinking the wires that go into the TPS sensor. Mine heads down underneath the intake and back towards the firewall. That would be the TPS circuit might try and dig around under there to see. I was told the ECU was either good or it was bad and wouldnt run is this correct?
The problem is everyonce in a while the engine will stumble for a few seconds then pick up and run perfect again. Also the Idle starts out perfect then falls and lopes between 400 and 600. It just isnt reliable when and where it will start acting up and as being a DD it would be nice to figure it out.
A completely dead ECM will not turn on the MIL when you turn on the ignition.
The ECM will usually throw a code or multiple codes when it fails.
A failed ECM will usually go into a fail-safe mode and will run the vehicle. Failed ECM's on 94 and up vehicles are rare. There are known problems with the 93 ECM and it will throw multiple codes (IIRC 82, 83, 84) when it fails. Your problem doesn't seem like a bad ECM but if you can find a spare to plug it in then you can try that.
I would start looking for air or vacuum leaks. What have you replaced or eliminated?
-B-
replaced cap, rotor, plugs, wires, air intake tube, TPS sensor, Re wrapped wires around EGR, Cleaned out PCV valve. It runs worse when the engine is cold it stumbles a little on acceleration. Once it is warm it runs fine but sometimes it will just cut out bad then something will click and it will run perfect.
Did you take it apart at that point and inspect each and every wire carefully?
Have you checked the coil and the igniter? I don't know the testing procedure but there is probably a section in the FSM.
-B-
Did you ever solve this problem? I am having a similar problem but did not want to start an all new thread.
