st st stuttering
Boise ID
Just got a new 80 series with the 1fz-fe engine and it is sputtering and cutting out. Said to have 80K on the engine and tranny and 207 on the rest if that helps out at all.
The problem -
It has only done this twice but while driving 50-70 it will just start to lose power and probably drop 1k revs then pick up then drop again and so on for about 10 seconds then it will go away and be fine.
Under acceleration it kind of sputters til about 2K then takes off and runs great. Then while I am stopped it will idle at 600 for a few seconds then drop and jump between 400 and 600. Happens really bad when it is cold. Takes a while to build up speed.
I am thinking the fuel pump is just not giving enough juice and I heard they are two stages because it runs great and high rpms but the lower revs it sputters. Also think this because with the idle coming from higher revs there is pressure built up so it idles fine for a while but after the pressure drops the fuel pump is struggling and it decreases and stutters. Checked the oil no white crud and antifreeze is the right color.
One thing that scares me is that when I take off the oil cap its like it is under pressure and it drops and runs like crap until put back on.
I could be wrong but anything will help this is my DD and kind of want to get it running a lot better.
If you take off the oil cap and it's under positive pressure...for starters, sounds like the PCV is not doing it's job at sucking the excess blow by fumes back into the intake. At least clean it out with some solvent and blow some air into it. It's located on top of the valve cover and may be a little difficult to slide out depending on the age of the rubber grommet.
Do the easy things first I say!!!
Dist cap seemed to be all right but I will get a new one along with wires and plugs just to tune it up a little. Going to check the air intake tube but that wouldnt solve the problem of why it cut out while going 50-70 though. I am going to clean the fuel pump relay and see if that helps out also.
Thanks I will try that. Will be great if that is it.
That won't solve your engine at speed issue but at least it'll eliminate one suspect.
If you suspect the EFI relay, perhaps just swap one with someone else as an experiment? The fuel pump relay may swap with another one in your vehicle as I don't think it's anything special. I don't have the FSM in front of me unfortunately...
