One of my TPMS sensors reads 7-9 psi below actual inflation pressure, so it trips the warning lights.
Does a low battery cause low pressure readings? It’s one of the first/fastest sensors to register the pressure on the display after start up.
I had some that were replaced within last 2 years by a tire shop. I *think* it was one that was replaced, but not sure. Since I got all 5 working, this one has always read low, used to be about 7 psi before, but was 9 psi off this morning.
Is there any way to calibrate the TPMS with computer? I.e. tell the computer that it’s reading 35 psi not 26?
Or is the only solution replacing it?
