tpi chev into 80series?
mildura australia
anyone seen or have or got or have pics of an 80 series wwith a tpi chev in it?
a guy is wanting to put one in his and we are trying too figure out what the bonnet clearance is and weather it needs modding?
any help greatly appreciated guys:cheers:
It'll fit with no mods. Clearance will be fine.
Search for a member named "WhiteShark", he put a 350 in his.
Several other members have put various V8s into their 80s, i.e. Toyota 4.7, Chevy LT1, Chevy 350/305, etc...
The TPI should fit without a hitch. Some of the other references are to non TPI swaps. But there is plenty of room in there.
The question would be, Why? You have an inline engine borrowed from a tractor, that has the highest torque numbers around for the displacement, and you want to swap it for a V-8??
The GM engine has half as much iron in it, is not nearly as stout, and produces only a bit more power when not modified. A V engine has much less torque than an inline, and most V8 mods reduce torque while adding ponies. Are you towing a huge boat? Or are you going to wheel? If you tow, buy a full-size truck. If you want to wheel the truck, the V-8 will disappoint you. The inline 6 works better.
There is a reason that Toyo kept the inline 6 for over 45 years. It is because it can climb trees! They only gave in to the V-8 sickness when more soccor dads towed boats than they wheeled trucks. You see very few lifted 100's for a reason. It is because V-8's don't climb rocks very well! A V-8 is a car engine. The inline 6 is made for a tractor. The 80 is a tractor with leather and air conditioning.
