- Location
- United States
Haven't used it since June of 09, so it's time to find it a new home! SOLD!!! Brian@jcroffroad.com
Full Build up, from Fall of 2008
Specs:
69' Toyota FJ40 Frame, hood, bib, bezel and firewall.
Titled as a 85' Toyota Pickup
3200lbs
Engine:
Rebuilt 22r (less then 100 miles, aprox. 50 hours of run time)
Propane Injection (includes two propane tanks)
Headman header
Yoke OBA Pump with air Tank
OBW setup made using Ford Alternator (includes 4" Grinder, Welding Leads, and rods)
Yellow Top Optima battery
Electric Fan
Transmission:
Toyota L52 with Marlin Crawler rebuild top cover.
Tcases:
Dual Tcases with AA adapter. Stock gearing in both cases.
Front Axle:
5.29 Long Cryo'd Gears Toyota E-locker
30 spline longs
Vented Rotors and IFS Calipers
newer bearings and seals.
Hi Steer arms
Full Hydro Steering (SA ram)
Rear Axle:
IFS Housing
Disk Brakes with Chevy Parts
Welded Diff
Driveshafts:
Heavy wall toyota shafts.
Suspension:
Sway-a-Way air shocks.
Triangulated 4-links front and rear.
Currie Johny Joints on one end, poly bushing on the other.
Interior:
All AutoMeter gauges (Speedo, Tach, Oil, Volts, Water, Air)
Corbeau Suspension Seats
Simpson Cam-lock Harnesses
Inchworm Billet Shift knobs
Uniden CB
Large locking military storage box in the rear.
37x12.5x17 BFG Krawler Blue Labels, grooved.
17" Allied Aluminum Beadlocks
Newer Warn M8000, Synthetic rope, aluminum hawse Fairlead.
Specs:
3200lbs
Engine:
Headman header
Electric Fan
Transmission:
Tcases:
Front Axle:
30 spline longs
Hi Steer arms
Rear Axle:
IFS Housing
Welded Diff
Driveshafts:
Suspension:
Interior:
Uniden CB
