Toybox!
Well, I finally got through to Marlin Crawler last night and ordered my Toybox. My first step in modding my cruiser. Next will be to rebuild the 700r4 and install the new tailshaft, then buy a 350 and bolt it all together. I am psyched!
It will go behind the 700r4 to a L/C 4speed transfer case. SOA at the same time. Right now I'm collecting the drivetrain parts and saving my duckies for the rest. I'm going to flip the rear springs because I'll be looking at a really short rear driveshaft, but the upside is the front d/s will be so long I won't have to do a cut and turn
Depending on where you are in VA, Mountain Run Machine Shop in Culpeper does good drive shaft work.
Is it a useable engine or does it need rebuilding? And how cheap is cheap:). I'm east of Richmond.
I PM'ed you back
I have a toybox in my 55 and love it. Put it in low, engage the toybox and just let the clutch out. I think it would just chirp the tires and hop if I put it up against a brick wall. Awesome.
I was just pondering being able to do this mod myself. The "toybox" is basically an adapter that allows you to use another low gearset and in essence have a dual transfer case setup right? I wanted to put a 700r4 (sitting in the garage) but was afraid I wouldn't have any room left for the driveline with it let alone with another additional 6+'' with the toybox. Isn't the length with the two almost a foot and a half longer? I know you can get a few inches with a spring flip but....................:confused:
The toybox is only about an inch or so longer than just an adaptor plate. I have had 700r4s in a couple of trucks and have been happy with them. I like the overdrive for highway use.:)
