Using a tow dolly takes all the drama out of towing a 40. I have both, along with a trailer, and have flat towed, dollied, and trailered 40's, 60's, etc. all over the southwest. I'd go trailer number one, dolly number two, flat tow last option. There's no problem flat towing if you realize the limitations. A half ton pickup when flat towing will be a big problem in less than optimal traction conditions...the weight of the cruiser will push the rear of the truck out on turns, especially tight ones. Additionally, steep downhills can be a white knuckle ride. Tow dolly eliminates all this. A friend of mine tows his 40 behind his travel trailer, but it's a fifth wheel, I wouldn't even consider it with a bumper pull trailer, fifth wheels are much more stable. He limits speed to around 60. I have towed my gooseneck coast to coast with two 40's, or a 40 and a 60, no problems, but you're limited by braking, and the dot is getting to be real bad in Tx. You can flat or tandem tow legally in TX or NM. You are limited by overall length in both states. Side note...I have about 5 tow bars lying about if anyone wants one cheap and doesn't mind paying shipping.
