Tow Rigs - Lets discuss
Got to admit driving through the rivers looks like a ton of fun.
Well it started out as a EGR delete.....:rolleyes: then after a few minutes of talking to fellow on the other end of the diesel shop....
H&S Egr delete kit
H&S Pyro
H&S Mini Max Programmer
4" turbo back exhaust
I can honestly say- BEST mods ever.
Truck had power before- now on the 3rd setting- it has stupid power:eek:
It has no power, mild+60hp, wild+120hp, and Hot+175hp settings at push of button:grinpimp:
Daily I leave it in mild & can say it drives amazing.
Another thing is; mini max gives me control of all options & monitoring of everything.... and you can control everything from A/T shift points to stuff like seat belt reminder.... I dont have a A/T but still controlling all this is great.
Cant wait for October to see how it tows.
See yawl there.
Hey bud check out your software revision on your Mini Max mine was way out and I'm updating it right now. You can also put some custom tunes on there, I'm not that brave yet :lol: Here is the link
The latest is: 6.7.39 Aug. 23, 2012 – Factory pyro solution firmware adjustments, (OD 68.8)
http://www.hsperformance.com/update-instructions/
Larry thanks for the heads up- today was trailer work day.
Have you driven it since the update...?
Notice anything>?
Notice anything>?
Your most welcome bud. I drove it today it was hard to pin point exactly what the different is but it sure does seem like its better balanced across the power band. I was about 5 updates behind the revision I received it with.
Well, i had posted a while back about having problems with my f250, running really rough and the SES light being on. I finally found the problem and fixed it, it was the UVCH(under valve cover harness) on the passenger side(of course I changed both), it now runs like a champ.
Awesome. I remember that, but know nothing of the fords. Glad to hear ya got it running again. :)
Thanks Cody Sent from my iPhone using IH8MUD
Glad to hear it bud, can't say I heard of that valve but now I have :)
Good bud... now put it in front of a trailer w/ your shiat on top of it and head to Arkansas ;p
well a slight problem my "junk" is 5 1/2 hours down south....still. I was really considering driving up and camping with yall but as it turns out, my Wife's class reunion stuff is happening this weekend. maybe a end of year ride or something. *crossing fingers*
We're in the same boat... Ima try to do a barnwell trip December 28-30
Programmer set to stock
Going 14.2 mpg running 65 mph
Return 13.8 mpg running between 67 - 70 mph
Pretty much an even 10mpg for me with the programmer on 40% which is a tow mode. But I threw some kind of code that was not allowing me to downshift on the ride home so I was trying to use downhill momentum to carry me up the next hill. For some reason the programmer would not read any codes so I hope to get into it in the next day or so. But I figure 10 is not bad for towing Clifford with Hachi on back at 65 - 70 mph.
Not bad at all Mike with that load, did you weigh your setup to know what kinda weight your hauling? I think Paul said he was doing about 10 as well with 23.5K behind him. Hope your programmer bug gets worked out maybe it just needs a reboot :)
GVW 23,280lb
@ 65 most the time a few above 70
going up on biodiesel 8.5 MPG
coming back on diesel no gumbo less beer a bit of mud 9.3
I started off getting 16, but by the time I got the Memphis, the winds shifted and I dropped down to 12. Not sure what engine I had, but the tow rig was a GMC van with a 10' box. Would that be a 6.0 liter still or are they running a 6.2 now?
I didn't weigh it yet but I am estimating somewhere around 10k - 11k on the rig and trailer loaded. I need to drag it to a scale soon.
You might be a little heavier.
Dads gmc. The land cruiser, 4 wheeler, trailer, and gear with me weight in at 16,865 lbs. that's without a camper. You have to weight a bit more than 10. I know the 62 is heavier than the 40, but still.
Sent from my iPad using IH8MUD
