I just received two front tow hooks in the mail. My rig has no bolts in the underside of the bumper bracket to hold the hooks. Does anyone know the size of these bolts??? Thanks guys.
Don't forget to get the lock and plain washers to go with the bolts. Have fun installing those hooks/loops
You're welcomeDon't forget to get the lock and plain washers to go with the bolts. Have fun installing those hooks/loops
12mm x 1.25mm x 45 mm. Make sure they are grade 8 bolts. I think Home Depot and Lowe's carries these bolts on their bins.
12MM O.D. by a 1.25 pitch, length is about 50MM, Grade is 10.9.Bringing up an old thread because I don't think the answer was clear and I also have an additional question. First, what is the correct bolt size / pitch? Also, I have one that is stripped out. How do people suggest I fix this? TIA.
And how do people suggest I deal with a stripped out captive nut?
The original bolt your replacing is a 12MM X 1.25 thread pitch.So I should remove the current one and weld in a new one? Or can this one be tapped to another size? And if so, what size?
