Torquer Cam and Timing
It doesn't have any effect on the timing. Just vallve performance
Right. You'll adjust your valves with different feeler gauges than stock. Timing procedure is unchanged.
Goozey said:
PO installed a Downey torquer cam in my 77' (2F). What effect, if any, does that have on the timing?
If you are referring to ignition timing:
as a camshaft gets more "radical", the optimum timing point is advanced because of the reduced cylinder pressure.
Thanks Jim
I should have been more specific on the timeing. Is there a formula or rule of thumb to know how far to advance the ignition timing with a torque cam?
