Torque Values Help Request
DrRock
Supporting Vendor
Kent, CT
Hello All, I’m getting ready to marry my new transmission to my new engine and need the following torque specs. If someone could provide them or point me in a direction where they can be found, I’d be thankful. Engine is a 2F and transmission is an h55
Flywheel to crank bolt torque
Bell housing to engine block bolts
Pressure plate to flywheel bolts
Bell housing to transmission bolts
Cheers, James
Do a search for the Toyota Maintenance Manuals -vehicle and engine - in this forum. AFAIK, every torque spec you could ever want is at the end of them.
Cheers, James
Per the 1980 2F factory service manual:
Flywheel to crank bolt torque: 58 - 79 ft. lbs.
Bell housing to engine block bolts: no values given
Pressure plate to flywheel bolts: no values given; may be in the Chassis manual
Bell housing to transmission bolts: no values given; may be in the Chassis manual
The Toyota manuals have all the torque specs — and nobody should be working on their truck without referencing those manuals.
