torque spec - tie rod
Can I damage by over torqueing? I tightened too much and my threads on the castle nut started to distort. the tie rod bolt looks fine. If I get a new castle nut should I be ok? I thought I read in the haynes manual 130 foot pounds.
Greg
Greg
:eek: 130 ft. lbs. is way to much...you will :censor: up a lot more than your castle nut trying to reach that torque. Torque to 65 ft. lbs., if the holes don't line up, back off the nut untill they do.
