torque setting suspension
Is there a number that will work for torquing my suspension? :beer: I just put on a skyjacker 4" and there was nothing in the instructions of torque settings. :cheers:
I just installed a pro comp springs and I think it was 65 ft lbs on the u bolts and 35 ft lbs on the shackels.
you gotta make sure
that when you go to torqe your bolts, that your rigs weight is all on the ground.
DO NOT TORQE YOUR BOLTS WHILE THE RIG IS IN THE AIR!
YOU WILL PRELOAD THE BUSHINGS AND SPRINGS.
I heard something like 80 ft. lbs. but you are the only one who has replied so 65 and 35 it is. Thanks for the help.
