- Thread starter
- #21
I just bought a marks adapter for my fj60 and have a 95 suburban with the 6.5td. Does the burb have hydroboost system that I need for the 60 and how did you wire your glow plugs? Thanks
I am going to guess that the suburban uses hydroboost, and you would just adapt the hydrobost master and booster to your brake pedal.
You can also just use the stock vacuum booster, and then use the vacuum pump to boost it. It is a lot easier to join those systems than it is to use the GM booster and master.
