Topless Rocks
Colorado
I just bought my cruiser a couple of months ago. With the hardtop on it is kinda clunky and not much fun to drive. Weather in CO got pretty good the last couple of weeks and took off the top. Talk about a difference, it seems to run better and is a totally different rig. I was going to buy bigger tires but now I'm buying a softtop that rolls up on the sides and some soft doors. Anyone have soft doors? How are they, do they rattle alot? How are the windows, I've heard from Jeep guys the windows are a pain, anyone? Thanks, and I gotta say topless rocks.
Welcome to the club :D
The significant wieght difference is what makes the truck feel so much better- I know exactly what you're talking about.
Soft doors blow, plain and simple. They do not seal at all, and flap at speeds above 40 mph. The windows are not that big of a deal.
top off kicks ass . its the only way i drive i also live in california and the weather does get that bad i agree soft door s suck i think the way to go are half doors made from steel or alum.
Hi All:
You might check-out the existing thread about soft top vs. hard top.
Regards,
alan
soft doors really aren't great, but they keep the weather out. which top are you going with? both manufacturers are local.
don't forget to swing by the next rising sun meeting (wed april 6th) and show it off ;)
Thanks for all the hello's, been a lurker on this site for a while now. Like to buy a top with the zip out windows, I think that would be the best of both worlds.
I do have another newbie question, I am sure someone that has owned a cruiser awile can answer... :rolleyes:
I get a pretty good vibration at highway speeds, a new tune up and a harmonic balancer took care of alot. I was planning on some angled shims, have lifted shackles and Rancho 2.5" lifted springs. When I took the top off the vibration for the most part went away.
What gives, I thought the pinion angle would increase with more arch in the springs, given the lower weight of the back end without the hardtop? :confused:
Thanks.
No tellin man.
Best thing to do is pull the driveshaft, measure pinion and tcase output with a degree finder and then buy appropriate shims. While shaft is out grease and check ujoints, and make sure they are "in phase." Search if you don't know what I mean.
Then check tire balance and front wheel bearings.
Also anyone know where to get "door pin inserts" for less than $45 for three?
My doors work fine
I have a Kayline top and doors on my 68 FJ40 and it works as well as any soft top.
The doors are great, though the latches needed some rework before they worked as well as I wanted. The top sections pull off easily so I have half doors is I want.
I drive mine year round in Wyoming and though it may get cool inside, I haven't froze to death yet.
Plus I can have a roadster in just a few minutes in the summer and that's really great.
Paul
I have an older kayline on mine. It works good, but the doors do suck. Mine has the old twist style latches that never seem to work right. They squeek like mad unless you wrap the strikers with tape too. And the strikers seem to be good at catching you right in the side of the gut as you get out if you're not careful. But the newer stc version supposedly has much improved door latches. I'll definately buy the newer version when mine wears out. I love the top, just hate the door latches.
