I'm in the process of gathering parts to do power steering along with a SOA on my 74. I have the axle and hy-steer setup, I'm not sure on my choices for the drivelines. There is a local shop here in town(Mountain Driveline)that could lengthen them for me, will I have to do front and rear? Should I look for a mini front driveline(CV type)? Also can I use shims if the pinion angle is not exact, as I bought this axle from someone already cut and turned?
Now on the steering...Can I or should I use the hy-steer with a mini ps box setup like JT Outfitters offers? Another option that I was looking at using Downey's saginaw kit, and pulling a junkyard pump and gear box. But I'm still looking at 400$ for the kit. I know I could piece something together for less, I would just like to be able to order everything in one shot and have it fit right.
. As far as the rear, I went with Tom woods c.v. and pointed the pinion straight to the t-case. The front, since you have a cut & turn my opinion is no good here. You're one up on me. I would deffintetly run the c.v. as well. There are quite a few 4-wheel parts places that carry an adapter plate for the mini truck to L.C. drive lines.
. IMHO, I'd settle w/ the 4-1/4 turn 4 bolt cheby sagi. box and spend the $ somewhere else b-4 I'd buy the AGR. Although others will prob. disagree
