Toe-in setting 'jig'
Omaha, NE.
After I installed my lift, I wanted to again check and adjust my toe-in if necessary.
In the past I've used the method of measuring from a tire-lug to a mark on each tire.
This method seem reasonably effective, but I wanted a way to do it without having to crawl under the truck, or roll the truck back and forth repeatedly. Also, once you go for a drive, you have to reset your mark on the tire. So I also wanted to be able to stop in a parking lot, adjust, and drive again.
What I did was to get 2 3' long pieces of 1/2" angle aluminum (available at most home stores, longer pieces needed for larger tires) and a way to hold them against the tires (I used hold down straps). The straps are just tight enough to hold the aluminum snug against each tire and keep it from moving when you measure. Each aluminum piece is equidistant from the floor and kept level.
The nice thing about this is there is a solid edge to securely hold the far end of the tape, and a sharp edge to measure to accurately.
For those that have not set toe-in before: Measure between the tires at the rear of the tire, then at the front of the tire, and adjust the tie rod to get the desired toe-in (I'm at about 3/16", and it seems about right for my truck. YMMV).
That's no good. :D The tire is not perfectly round. I tried something similar and got different readings every time I checked it after driving. I solved my problem by making a bar with standoffs that contact the wheel instead of the rubber. I use a similar method to check camber (I h8 IFS).
-Spike
You are thinking too much!!
It is a good idea, but it is not effective. You need to use the wheels as a lathe to make a center-line.
Use the concept of KIS, Keep It Simple!
First, raise the truck so that the front wheels can be made to spin under power. Get them turning. Then spray white, silver or other light colored paint on the tire while it spins, making a stripe around the tire on the tread near the center. Then take a nail, scribe or other sharp tool and make a line around the tire. That line is your alignment line.
you guys are, as usual, over thinking this.
Put the bar in the center of both front wheels (meaning perfectly lined with the center hub), take measurements.
It's not rocket science.
or your could take your wheels off and use the rotors if you were going to be diving in for some other projects as well.
yes and, as you know surely, but for general consumption one could add that measuring in absolute inches or mm won't mean much, and obviously so from the rotor since its diameter is much less than the tire. Either way you need to convert to angles for this to make sense. Even for different size tires, one can't compare too well if it's in inches. Well, OK, at least inches will tell you if you're positive or negative, that's already something...
I read another thread where you push thumbtacks into the tread at 3 o'clock, measure the distance. roll (or spin the tires if jacked up) the truck back so the thumbtacks are at 9 o'clock. That gives you the toe.
Ivan80, you have built a better mouse trap. Doing a toe set is not rocket science. Most alignment shops with older racks will do toe sets in the same manner as yours.
I think FJ Ben meant something along the lines of this:
I respectfully disagree.
Thanks CJ. I'm sure others are wondering why the bar isn't centered in the hub also. The reason is that the control arms are in the way of the rear measurement.
Thanks. 20 years ago I worked in a shop that had an ancient (even then) Hunter rack. I got this idea from recalling the alignment clamps. The only improvement this needs to have is stand-offs added to use the wheel instead of the tire (per Spike) or use the rotors. Although this is accurate enough as long as the tire run-out is within reason (I'm not running 35's).
:cheers:
