To plug or not to plug?
Calgary alberta
should these ports be plugged?
The one on the manifold, yes, unless you are venting the fumes from the tank to the intake manifold via something like a Vacuum Switching Valve. The choke breaker on the carb is kinda essential equipment for a nice warm-up, unless it is a vac leak. What is going on with your power valve on top of the air horn?
I was told to connect the one one the manifold to the choke breather,is that right?...power valve?still learning part names ...kinda new to carbs
Blue circle, test it. If it pulls vacuum on its own, it is a useful source for the vacuum for the choke breaker. If it does not pull vacuum, then the power valve that is linked to it internally will not work properly.
Manifold vacuum is further into the engine than in the throttle body, where the power piston optimally gets its vacuum signal from. It’s not a big difference, but in a passive fuel management system, every little bit counts.
Blue is your '75 USA spec Auxiliary Accelerator Pump. The small barb on the green at the bottom of the image is the manifold side of the Vacuum Switching Valve, collecting fumes from the gas tank at the proper time and quantity. The green barb above that is a diaphragm which operates the Choke Breaker. I have what is probably called a 'gas filter,' that gets three barbs out of one hole on the top of the intake manifold, you have an 1/8" pipe plug there that normally goes on the other side of the manifold. The internal power valve routing is present in the casting on two of my '75 USA-spec carbs, but they are dead-end routes, the job was handled by the VSV in a stock config. Blue circle is the AAP, (I don't think that you will be able to pull vacuum there), you might want to hook it up as described below.
(See FJ40Jim's post #8 on this thread) Desmogged '75 FJ40 vacuum routing help
Do you have two vacuum barbs on your thermostat?
No barns on thermostat
What side of the diaphragm is the barb on your distributor? The outside, or the cap side? Is this a Canadian-spec FJ?
If you cap, find good ones which don't rot within the first six months. Are they selling ethanol in their gas in Alberta?
