I've finally installed a 4" lift in my '97 LX450. I called up Extreme Land Cruiser and ordered up a set of TJM 4" springs, shocks, panhard rods, Ironman caster correction plates, and other goodies at Ryan's advice (parts I knew I needed anyway, sway bar drop blocks etc.).
I started installing the kit last week because I was supposed to be chasing a friend of mine who was supposed to be racing in the Baja 1000 this week, unfortunately he ended up breaking his ankle pre-running the other day so plans have changed. I'm no longer heading down there, which is just as well really since the suspension is certainly not long distance road worthy yet.
I like the stance that the TJM springs offer, and the fact that they are now available in black. I really couldn't find anyone who had anything bad to say about their parts and since Slee and other vendors are selling them now I figured they must be good. Installation went relatively smooth, I did end up fighting the TJM adjustable front panhard rod though, which is something that I think is now causing me grief with front end geometry (read on!)
Other problem areas that I encountered are the TJM extended brake line kit and the Ironman caster correction plates. TJM only has 2 brake lines in their kit, which should really include a third. The one that should be supplied for later 80 series is the front axle brake line that travels from the passenger side frame to the axle assembly, the stock Toyota brake line is quite stretched at full down travel.
I only received two brake lines in my kit, whether or not this is right I don't know, I haven't heard back from Extreme Land Cruiser on that yet. Christo Slee believes that TJM is aware of this problem, hopefully they make good on setting their brake line kit up with this third brake line.
Ironman caster correction plates are problematic as well if you have a LHD Cruiser, the front upper bolt won't pass through the caster plate, it's bound by the diff on one side and the panhard rod bracket on the other. Competitor's caster plates for the North American LHD market utilize a pair of 1" (25mm) long bolts to mount the passenger's side caster plate at his bolt hole. Keep this flaw in mind with their kit, I'd just recommend buying someone else's kit to avoid the hassle of having to buy bolts elsewhere, hardware that should really be included.
The biggest problem that I have however is with the front driver's side spring getting caught on the metal bump stop cup. I took the Cruiser out for a quick drive after I got the suspension in and the brakes bled and it didn't ride that great. I ended up driving on a road with quite a bit of camber on it and it felt like it was high on the driver's side. I then drove into a parking lot where I hit a speed bump, I heard the familiar "twang" of the spring hitting something.
I got out and found that the driver's side spring in the aforementioned condition, and the spring even had the powder coat chip off where it hit the metal cup. The passenger's side front bump stop isn't in the center of the spring either, but there is plenty of clearance for he spring to travel.
I realize that caster correction plates effectively shorten the radius arms, but this doesn't explain the difference between the driver's and passenger's side spring position. My truck is in good shape and has a collision free history, besides, the geometry was even before the lift install.
I think the cause lies with the TJM front pan hard rod. While the construction is solid, I questioned its trueness on install. I dropped the factory rod out with the suspension loaded, it popped out fairly easily. When I went to install the TJM rod (again with the weight on the wheels) I had to force it over 4 inches or so and pry and drift it in with a hammer, when I did finally get it in and the bolt holes close, I had to fight some more to get the bolts to start in the holes (the bushings are not parallel to the bolt holes). At first it was the urethane bushings that were tight (even after I greased them up) but it soon became apparent that the rod ends aren't true, it's as if the ends are offset.
Once the suspension settled in the driver's side radius arm seemed to travel down, the shock on the driver's side is extended the better part of an inch or so more than the passenger's side. It's not so bad that you can see it just to look at it from a distance, but something isn't right. I think that the panhard rod is offset and bound up, hitting the speed bump in the parking lot jarred it free and caused the driver's side radius arm to drop and shift the axle spring perch to kick back causing the spring to draw back in relation to the bump stop.
Tomorrow I'll reinstall the factory panhard to see if the axle sits in a better position. I'll post photos tomorrow as well.
