ARCHIVE TJM 2016+ TOYOTA TACOMA FABRICATED UPPER CONTROL ARMS
Sacramento
The TJM fully fabricated upper control arms are 100% bolt-on and designed to work with any suspension lift 2.5" and higher. TJM fabricated arms where designed to bring your factory suspension geometry back to OE specifications so you can correctly align your vehicle while maximizing over all suspension travel.
Features:
Hi Strength, Fabricated Box Design
4mm Thick Mild Steel
Maintains ABS Wheel Sensor Harness
OE Quality Rear Bushings
OE Quality Ball Joint
TJM Billet Aluminum Ball Joint Dust Cover
TJM 2010+ Toyota 4Runner Fabricated Upper Control Arms
Are these UCA's compatible with the 4WD trucks or just the Prerunners, as pictured, only?
