Tire question
KLF
Frame waxer
Southern NH
No, not the usual "will these tires fit" or "what tires should I buy" questions.
Brother has a '96 FZJ80. Some punk slashed two of his tires the other day. He only replaced the two, not all 4, same size but not the same brand. The other tires are kinda worn, not sure how much though (truck is 500 miles away from me). Is this gonna be a problem with the AWD system? He has the new ones on the passenger side F&R.
I have almost no experience with 80's, but I do know that the Owner's Manual for our AWD Highlander has several warnings about always keeping all the tires identical.
Thanks.
Thats too bad someone vandalised his LC. As long as the tires are marked the same size, it wouldnt be a problem, esp if the others are only slightly worn.
From a basic tire perspective though, IMO the tires should be paired up on the same axle vs one side.
x3 The tires should be paired up on the same axle, the viscous coupler in the center diff should take care of any slippage, due to a small difference in size between the front and rear axles.
......Brother has a '96 FZJ80. Some punk slashed two of his tires the other day. He only replaced the two, not all 4, same size but not the same brand. The other tires are kinda worn, not sure how much though (truck is 500 miles away from me). Is this gonna be a problem with the AWD system? He has the new ones on the passenger side F&R...........
For a short time, it shouldn't be a problem. But in the long run, it will cause excessive wear to the VC and possibly axle diffs if Murf's warning in post#2 is not heeded. One of the biggest drawbacks, IMHO, to the HF2AV with the VC, being this need for 4 evenly matched tires.
No dis-respect intended, but I don't think you understand the VC's purpose. It is not to allow slippage, but to limit slippage to aid in traction. The 80's transfer case with the center diff (unlocked, of course) allows the slippage. It's the constant working of the VC from different driveshaft speeds due to unmatched tires or slick surfaces that will cause it to overheat and eventually seize.
Any time the VC is worked, it heats up. When used as designed, on good traction surfaces, the VC works very little - mainly on turns. When you work it hard with unmatched drive shaft speeds from either slippery surface or unmatched tires, you're going to cause excessive heat and wear and eventual failure. One good reason, when off road or on ice & snow surfaces, to lock CDL when traction is questionable.
Well, my thinking was it might be better to have the mis-match handled in the diffs instead of through the VC in the t-case. So I'm still not clear on what to tell him (other than to go buy 2 more new tires).
BTW, this truck is now for sale, the 12 mpg is killing him. I haven't seen it since last summer, I know it's kinda beat up. I'm begging him for pics, then I'll post an ad in the proper section. Yes, it has lockers. Currently located in Baltimore MD. He says he'll take $4K for it.
Well, my thinking was it might be better to have the mis-match handled in the diffs instead of through the VC in the t-case. So I'm still not clear on what to tell him (other than to go buy 2 more new tires)........
Unfortunately, this is the best long term fix. BTW, If he's going to sell it, it would be more appealing to well informed buyers with matched tires on it that are in good condition.
