Is there any way to get the tire pressure to show up on the gauge cluster instead of going to the touchscreen?
Nope.Is there any way to get the tire pressure to show up on the gauge cluster instead of going to the touchscreen?
Yeah. Couldn't find a way either. It was so much easier in the 200 using the small screen in the dash and the steering wheel buttons.Nope.
The weird thing is that the driver dash can show tire pressure for a bit when there's a tmps warning.Yeah. Couldn't find a way either. It was so much easier in the 200 using the small screen in the dash and the steering wheel buttons.
Exactly this. I saw it for a second when Lexus had to reprogram my tpms due to my spare not reading.The weird thing is that the driver dash can show tire pressure for a bit when there's a tmps warning.
"Hey Lexus, show tire pressure" also doesn't work
I had a RX 500h and it was the same thing. So i think it's their new OS. I really was hoping that the secondary infotainment would be the perfect place to have it.Exactly this. I saw it for a second when Lexus had to reprogram my tpms due to my spare not reading.
Doesn't work for 700h. If I you press the down arrow, all it says is press OK to customize. Then, among the avail display, none of them are tire pressure.We have the tire pressures showing on the instrument cluster display of our 2024 LX600.
You use the arrow down button on the steering wheel, press it three or four times to cycle to the TPMS display for all wheels + the spare.
You can do this at any time. Best to show it after you’ve been driving for a minute or two for best accuracy.
Might be because the 2024 600 does not have the digital cluster. So different options.We have the tire pressures showing on the instrument cluster display of our 2024 LX600.
Didn't know this. Good point.Might be because the 2024 600 does not have the digital cluster. So different options.
What? No warning buzzing light when the pressure dropped?I do wish this was available in the gauge cluster especially while with MTS engaged or in 4LO;
I flatted out the stock Toyos down in Ouray and didn't know till the back end got loose on some fast mining roads.
I was already running at 18psi so the warning light was already on.What? No warning buzzing light when the pressure dropped?
The center part of the 2022-2024 cluster is 100% digital. It’s just the four gauges (two on each side) that are analog/needle gauges. The center part of the cluster is where the tire pressures can be displayed. I’ll take and post a photo.Might be because the 2024 600 does not have the digital cluster. So different options.
i think he's meaning to say is that the tire pressure info in the gauge cluster is a 22-24 feature. 25+ doesn't have that ability. This could prob be done via software update i doubt lexus will do it.The center part of the 2022-2024 cluster is 100% digital. It’s just the four gauges (two on each side) that are analog/needle gauges. The center part of the cluster is where the tire pressures can be displayed. I’ll take and post a photo.
If it's like the land cruiser 250 it should be an option to configure it in one of the screens.i think he's meaning to say is that the tire pressure info in the gauge cluster is a 22-24 feature. 25+ doesn't have that ability. This could prob be done via software update i doubt lexus will do it.
I meant to say it is not the full 100% digital cluster.The center part of the 2022-2024 cluster is 100% digital. It’s just the four gauges (two on each side) that are analog/needle gauges. The center part of the cluster is where the tire pressures can be displayed. I’ll take and post a photo.
Thank God, the 300 is nothing like the 250.If it's like the land cruiser 250 it should be an option to configure it in one of the screens.
