Tire ideas
I have 285's on the :princess: truck. You can run 305's as well (wider but not quite as tall). I've heard of people running 315's with the stock suspension, but you will have rubbing for sure.
Haven't managed to rub the 285's yet, but it's a street queen.
Searching will net you tons of results.
I find it hard to believe that you dont rub 285/75R16. I rub my 295/75R16 once in awhile with my 2.5" OME heavy lift. I used to have 255/85R16 BFG MT (>33") and could not get it to rub no matter how hard I tried with stock sagging suspension.
Before my lift when I was running the 285/75/16 Nittos, I never got them to rub. Even when I took it to Anza Borrego and drove it to the base of Pinyon drop-off and back.
x2 285/75/16, no rub on stock or 2.5" ome med. I was warned the 295 might.
I have rubbed the rear inner rear fender walls with 285's and an ome medium lift with no extended bump stops. The lift probably allows for more droop which allows a greater angle when stuffing a tire resulting in rubbing (which might not occur with stock suspension that might not twist up as well). Really not something I worry about as it is a very mild (friendly rubbing).
here are my largest tires (255/85/16 cooper discoverer ST) on factory suspension. Although I like friendly rubbing ;), no rubbing here.
Were they fully stuffed? I thought the overwhelming consensus is rubbing of 285 with stock suspension.
Here are my 255s: If these were 285s they would most definitely rub:
