timing question
Orlando, Fl
On my 72FJ40 is the timing ball on the flywheel TDC or is it the correct advance for 600rpm idle when set on the timing arrow??? Thanks guys, I'm just still backfiring a little bit and I'm wodering if that timing may be the problem becuase the timing ball is set to the arrow currently. I do have 600rpm's as well.
//newrider
The timing ball is the original correct timing advancement mark. You also probably have a little line on the flywheel which indicates TDC...
The ball is 7 degrees before top dead center, iirc.
The line on the flywheel is TDC.
Time the engine with the vacuum line to the distributor plugged...I put the ball on the lower edge of the window....
Newrider said:
I'm just still backfiring a little bit and I'm wodering if that timing may be the problem...
This is not timing related.....when a distributor is not installed correctly/180 out, and you try and crank the engine, it will pop back through the carb sometimes...but if you have it idleing at 600rpms, and have oil pressure, then your distributor is installed correctly...again, the poping you are getting back through the carburetor is not timing related....
Find the source of your vacuum leak, and this will stop. :)
Good luck!
-Steve
Thanks guys I really appreciate it...I think I found the vacuum leak. One of the bolts holding the carb to the intake is stripped where it goes into the manifold. I tried JB welding it...didn't work, what do you think I should do to get that bolt in there?? Do you think if I rethread it, it will make the bolt to small??
I use studs and nuts to hold my carburator down, Dealer has the correct studs, not spendy and they work well.
Take the carb off and install a helicoil in the intake manifold for the proper size bolt. Not sure offhand what size - probably 8x1.25
Unless I'm missunderstanding you, and the top part of the stud is stripped. Then Pighead is correct, just reinstall a new stud.
I would remove the carb, clean it down, then take a good look at the mounting studs, they should be studs... but I am not sure about the f engines, anyone?
As it has been said remove the old stud and turn in a new one, then use some good gas compatable RTV, if I remember correct it is the permatex 2B tube that doesn't harden...
Reinstall then start your trouble shooting from there.
Good luck and keep us posted.
Rezarf <><
There are studs on F two barrel intakes...
X2.
-Steve
sweet....yea the bottom part of the stud is stripped...but its not the actual stud...its the hole it screws into.....I'll try ya'll's ideas...thanks again
