Timing Light
Sparks, NV
I plan on picking up a ScanGauge II that azcruiser had posted about and then I realized I need a timing light...any suggestions on a good quality timing light for use on a 97FJ80?:confused:
The Scangauge has an ignition timing display, although I'm not 100% sure whether you could use it for the same purpose as a timing light. Anyone know?
The reason for the question was I was checking the internet for Timing Light reviews and a couple had indicated that the difference in readout can be up to 5-7 degrees depending on some brands so I'm clueless at this point, if I look towards the high end like MAC they run close to $300...:confused:
For a top quality light at a relatively inexpensive price check out Ferret Instruments. They make them private label for a lot of the big names, good stuff.
GxT Home Page
no expert on those, but it would be amazing if even cheapos could be off by 7deg. This is no rocket science I would think. Just have the bulb fire quickly and you're good.
I seriously doubt the variance between lights to be of any signifcance. I've timed engines with different lights and I would have noticed differences of more than 1 degree. I personally have an old craftsman and it gives me the same reading as the Mac one that a local tuning shop uses.
Thanks for all the feedback, probably going to set the budget at $100 and see what fits...?
wow! my Crafstman cost me a whopping $5 at a garage sale... Works perfectly
