Timing issues
Hey guys, just joined today. I have been having a nightmare of a
timing/carb issue all week. I took out my distributer to clean it and
around it, and I also rebuilt my carb. When I put the distributer back
I removed the valve cover and the first spark plug, rotated the
engine until there was compression at #1 and watched the valves until they were opened/closed at the sequence 123, 5 ,7 ,9... Lined up the arrow on the flywheel with the 7btdc bb (I know there is a line also but I cant find mine). Dropped the distributer, and turned it until the points just begin to open. The rotor is facing the #4 plug and the #1 on the dist. Connected all vacuum lines, and tried to fire her up. The best I get is that she stopped backfiring, and just runs very rough with some white smoke out of the exhaust, if I open my choke at all she either backfires and shuts off or just shuts off. I have tried adjusting the distributer both clockwise and counter clockwise and this just makes it worse. I have also adjusted the idle and mixture screws on the carb with no luck. Im stuck and I have repeated the process at 180 degrees back and forth about 100 times. If anyone has any ideas please advise. Also, new dist, plugs, wires, rotor, and coil. :mad: Im running out of beer quick and I have already lost my voice!!
Time is of the essence..
Maybe it is not a timing issue. What is the timing like when it is running poorly?
There are two potential problems with removing and reinstalling a distributor:
1. If you don't get it all the way down and seated into the oil pump drive you will have no oil pressure and ruin your engine.
2. People tend to forget that the distributor rotor rotates as the distributor drops down (about 20-30 degrees) so that the rotor is pointing to the next cylinder in the order rather than #1. This makes the distributor off by a couple of teeth so that you run our of rotation (the vacuum advance hits the side cover) before you can set the timing correctly.
Getting that distributor in the right spot is a real PITA. If you refer to the fsm manual it has a picture of how to line up the disty slot with the lifter cover on the third cylinder. Then you drop in the disty and check the rotor position.
I myself just about went mad trying to do this with a GM type disty. Because it was oversized I had to get the rotor close to the number one position and then move the wires accordingly while trying not to push the vac advance into the oil filter. It was a real pain.
One thing I would recommend is pulling off the flywheel cover and cleaning off your flywheel, that way you can find tdc mark and mark it with tape or a yellow paint marker. it's only about an two or so inches form the BB and is a long slot.
if you set your timing to anything other than the bb you need an advancing type timing light.
Thanks, the wierd thing is is that my flywheel is clean, I just cant find any type of line, just the BB and a few square indents about 1/4 inch deep.
