Timing chain
Sonoma, CA
Website
www.myspace.com
I'm gettting close to 200k miles on my Cruiser, and I was wondering if the timing chain is something that should be looked into in the near future.
I'm going to look into the head gasket and PHH, but I haven't read anything here about anyone's timing belt or chain breaking and causing carnage to the engine.
Plus my step dad says most of his cars have had timing belt/chain problems when they reach about 200k miles.
But I don't believe I've read one thread about someone replacing theirs....
;p
When I took my cruiser in for 200K KMS (about 124275 miles) I was told everything was ok but if we are talking about 300K miles then I have a long way to go to hit 321869 KMS! :P
It's basically a lifetime chain unless the engine suffers some kind of abuse or other damage. My bro in law has 320,000 miles on his 93. Runs silent, runs smooth. Never had the head off.
DougM
;p
Now you do :flipoff2: replaced chain 2 months ago...not just chain but overhaul 1FZ and FE transmission..hmm... next what else need to be replace..
P.S: Thanks to CDan provided all the parts :grinpimp:
Your dad is probly referring to American cars for the timing chain replacement comment at 200k miles. Some American manufacturers uses linked chains and plastic teeth on the timing chain gears, not good for longevity but quiet. About the only thing that I know from Toyota's or anything running a chain is that the roller chains can LAST but the guides won't and when they go the pieces can get sucked into the sump pickup which can cause some damage. If that's not enough, without a guide the chain then starts hitting/rubbing on aluminum and gouges/cuts into it. (famous for the 22RE's)
Typically belts last 60k-100k miles. (Honda's went back to the timing chains...)
