Hi all.
Well, just waiting on parts now. Everything is off and ready for reassembly.
I was wrong about my guides-they were in three pieces !!!
Question- on the oil pump, there are two internal gears. I noticed they both have arrows on them. Is this to show front versus rear OR line up? If line up, then which side does the inside relate to i.e. the arrows do NOT line up. They either relative to left or right of each other.
Interesting thing - my chain is OEM from Japan and I know the chain has not been changed. The bright links that mark the timing of the cam/crank gear were NOT on the mark. They were, however, 180 degrees from one another. Strange. I was VERY careful when removing them and even looked before I took them off the cam/crank. Go figure. I know I am at TDC because Piston 1's intake is open as if I were to adjust the valves. Right??
Again, really not a bad job at all. Just time really more than anything.
Thanks guys
Thanks guys
