Timing chain noise...??
Hope this helps someone looking for powersteering part numbers as i was unable to locate what I was looking for with the search option. Im new to the group so i assume with a search i can locate supporting venders.....thanks again to everyone for the help.
Thank you for coming back here to post! It helps all in the long run!
You can buy a new one through McGeorge Toyota or through partsouq.
You may be able to find a used one from @slow95z or @arcteryx . They will check in here because I called them by mentioning them.
The gear you have is probably useable if you take some time to clean up the teeth will a file and a die grinder as @Tools R Us stated.
This has been a common problem when folks pull the pump and going the teeth. Most generally, they clean up the teeth and put it back together.
Good luck!
Gouge, not going.
Ive removed the pump and inspected the gear and all looks to be good. There was a slight nick on the top edge of 3 teeth that i smoothed out, but nothing on the face. Ive reinstalled it for the fourth time and now only have a slight tick. My 80's idle is stupid silent, and i dont think i could even hear it if the engine wasn't so quiet. Im contemplating now what im going to do next.
