Timing belt chain guard
Albany, NY
Hey all,
My car is in the shop in the middle of a HG job.
The shop called and said that the timing chain rail guard is a laminted rubber or plastic and the plastic (rubber) is coming off.
We don't know if this is a critical components or not.
If it needs to be replace the shop suspect a big job.
I need your collective help with two questions:
1. Is the rail guard plastic lamination is coming off does it needs to be replaced?
2. if it needs to be replaced, is it a big job (like taking the front engine apart, or can it be replaced easily?
I am already doing a lot of PM so I can't just do it because I am there. I will do it only if it is a simple or if must be done.
Since the car is in the shop, I appriciate timely help
TIA
Rami
replace it all while your in there...not that much more work with the head off.
It is a lot more involved than one might think. to do it right you will need to remove both pans and then the timing cover. I have done the front cover a couple of times with out removing the pan, but it is a real pain. All the studs will need to be removes and oil pump and when the timeing cover goes back on they will have to be real carefull not to mess up the figp and o rings.
good luck Robbie
