Why do ya need a jumper wire in the diagnostic plug to set timing??
Because the timing is continually adjusted by the ECU. What you're doing by setting the timing according to the FSM is setting the correct "baseline" timing. Once the jumper is removed the ECU can then take over and fine adjust. See the quotes from the FSM below:
2. CONTROL SYSTEM
* EFI (ELECTRONIC FUEL INJECTION) SYSTEM
THE EFI SYSTEM MONITORS THE ENGINE REVOLUTIONS THROUGH THE SIGNALS EACH SENSOR (INPUT SIGNALS (1) TO (12))
INPUTS TO THE ECU. BASED ON THIS DATA AND THE PROGRAM MEMORIZED IN THE ECU, THE MOST APPROPRIATE FUEL
INJECTION TIMING IS DECIDED AND CURRENT IS OUTPUT TO TERMINAL #10 AND #20 OF THE ECU, CAUSING THE INJECTORS TO
OPERATE IT (TO INJECT FUEL). IT IS THIS SYSTEM WHICH, THROUGH THE WORK OF THE ECU, FINELY CONTROLS FUEL
INJECTION IN RESPONSE TO DRIVING CONDITIONS.
* ESA (ELECTRONIC SPARK ADVANCE) SYSTEM
THE ESA SYSTEM MONITORS THE ENGINE REVOLUTIONS USING THE SIGNALS (INPUT SIGNALS (1, 4, 5 TO 7, 9, 11, 12)) INPUT TO
THE ECU FROM EACH SENSOR. BASED ON THIS DATA AND THE PROGRAM MEMORIZED IN THE ECU, THE MOST APPROPRIATE
IGNITION TIMING IS DECIDED AND CURRENT IS OUTPUT TO TERMINAL IGT OF THE ECU. THIS OUTPUT CONTROLS THE IGNITER
TO PRODUCE THE MOST APPROPRIATE IGNITION TIMING FOR THE DRIVING CONDITIONS.
