Time for spacers.
Bonsall, CA
Yup, it's time for spacers for me. I live over the pond so my choice of spacers is limited to those who want to ship overseas and specifically to those who want do do it relatively cheap (under $50).
I am looking for 1.5" spacers and so far I've found these guys:
http://cgi.ebay.com/ebaymotors/WHEE...ryZ42614QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
They ship 4 pieces for $40.
My question is if anybody has tried their products. They seem reputable as they only sell spacers and not, for example, plates, shoes, clothes, barbie dolls and a few spacers :)
You know, I don't feel like spending almost $200 and wait for three weeks only to find out I've bought some low quality crap. In my case there's no way to give products back as shipping would be too much.
If you could check these figures:
-6x5.5 Inch Bolt Pattern
-12mm x 1.50 Wheel Studs and Nuts
-CNC Precision Machined 6061 Billet Aluminum
-Wheel Studs are Hardened Grade 8 Carbon Steel
Does it fit? Are these 'parameters' good?
In the photos I can see that the nuts are tapered (self-centering). My wheels use the newer type of flanged nuts, so my logic tells me to use the provided nuts onto the spacers (contrary to the pic) and my nuts on my rim. Am I correct?
Yeah, I know, dumb questions but I wanted to make sure before I toss $160, which is quite a lot for me.
Thanx :)
Those look identical looks wise and specs wise as the 1.5" spacers I run on my truck with no issues.
Just a fyi, you have hubcentric wheels. None of the spacers for the 80 and 100 are hubcentric. It can be a pain to get them wheel to centered properly on the spacer and not have a little shimmy in the steering.
I would suggest when you mount them you get some extra conical lugnuts and them use 3 of them to bolt the wheel on first. Then use the factory ones on the other three. Once you have the wheel centered, remove the conical ones and replace with factory ones.
My death wobble was strictly unbalanced tires. I had them weight balanced at a tire shop and ALL of the wobble disappeared.
For being "non-hubcentric" - the 1.5" spacer still has enough of the hub out to center the wheel.
If you look at the hub closely you will see that only the last 1/4" (closest to the truck) of so is the hubcentric part. After that the hub OD steps down a little. Maybe 1/32" of less. So the piece that sticks out does not help with the centering of the wheel.
Those are the same spacers I have, from the same guy. I have the 1.5" spacers pushing my stock 15" LC wheels out flush with my flares. Looks much better IMO but the main thing is there is no wobbling or balance issues at all. When cruising (speeding) at 80-85mph on the freeway, the truck drives smooth and straight with no vibrations.
I've seen some cheap spacers (all made in Taiwan so make sure the machining is done properly) that were not machined right and the balance is off. Also be careful with the bolts as the billet spacer might be a softer material than stated and stripping it could be done very easily. On those type of spacers, I tighten everything by hand with a torque wrench to 100 lbs.
