Time for new gears
Northern Calif.
Anybody have a brand of ring and pinion gears they recommend.
It's time to change my 3.73's to 4.56's and I don't want some crappy gear that can't handle the tough stuff.
Running an 81 fj60 with 350 and NV4500 on 33" BFG's. Thinking of changing to 35" tires and I barly use 5th gear as it is. Unless I'm late for work.
Also... Anybody have any veiw's on the transfercase gear set from Marks/Advance Adapters. The 3 to 1 low Range looks like it might be a better idea than trying to fit a ToyBox.:)
Hello. I know this is my first post but I do have expierience this area. I have used and set up richmond and yukon gears in yotas nad heep's with and without lockers. The The only ones that have had failures were the yukon's. I would spend the extra few bucks and go with the richmonds. Also I rarely see bad bearings so I wouldn't buy them until it's apart and you need then. I am sure others have different opinions, espiecialy about the bearings. New bearings
i feel are a little harder to set up too
Thanks for the feedback on the ring and pinion.
Still looking for anyone with experience with the 3 to1 Transfer Case Gear Set.
The marks gears I have heard are nice but can be noisy. They are quite expensive too in my opinion. You plan on getting the 3rd members setup somewhere or doing it yourself? Did you have to modify the transfer case and driveshaft to run the NV4500?
Thanks for the info on the gear thread.
There's some really good info there.
As for modifying to fit the NV4500 trans. Just have to have the driveshaft lengths adjusted a bit and make your own/modify the trans. mount.
No modification to the transfercase was needed.
I've been running this transmission for at least 10 years now and have no problems with it except the stick vibrates in fourth gear and has ever since i got it.
Ken
I should mention that the NV4500 I have came from Advance Adapters and was adapted to fit th L/C transfer case.
marks are noisy.. I would do the toybox just for options...
Also, on gearsets.. I have not seen any real failures in gearsets (cept for pinions). I do believe that Yukons are "economy" sets.. but personaly, I have not noticed them to be any harder to set up than any other brand..
Cruiseroutfitters.com has excellent deals on gearsets..
