time for a toybox...
ravenna Mi sittin 10 deep.
Well I got the $ for one right now.The question is witch one?It going in behind a h42.The question is what transfer case would ya run.I have a 1970 3 speed one, a 1978 4 speed one or I have a 1987 split case.Witch would you run and for why.It's going into a SOA small block cruiser.Locked front a rear.So what would ya do? Thanx
A tack on related question for Poser...
I am going to 60 springs on the back of my 40, which moves my axle back 4 inches or so. What do you tink about a SM420, toybox, Split case(which I have). From the Marlin website this looks doable.
The truck will be SOA, but still powered by the original 2F.
-------HIJACK-----------
I installed a 465/Toybox/Orion in a '69-40 a couple years back....you should not have any problem with this combo....
Your rear drive shaft might start to get short for SOA, but you should be able to make it work.
:beer:
Thanks, the short driveshaft is what gave me pause, but I'm getting some back with the FJ60 springs. Maybe an Orion behind my SM420 would be better?
I'm running a 465 2:27 toybox and a stock split case(38 mm) and once in a while I think I'd like the 4:7 gears in the toy box. go with the split case for sure and just do the 4:7 's that would be right around 156:1 and then you can still use the stock split case for playing in the sand.
Andy..if you go with the orian what will you use when you play in the sand?
4.0 is way too deep to play in the sand
