thats good to know. Thanks, I havent bought anything from them yet but i have gotten close. So far my best experiences have been with ccot. Sor seems to be alot higher in price and shipping is a robbery. I have been waiting on some brake lines i bought from Cruiser Solutions for over 4 weeks now and they wont even email me back.
Kind of gets away from the original question, but brake lines are available from any decent parts store (at least here in Canada). If you need steel lines, you can make your own quite easily, or buy standard lengths and bend then to fit.
For steering...
There are two different taper sizes common Cruisers, and a number of different thread diameters (17, 21 & 23mm).
American stuff is usually a 1:8 (1.5" per foot) and most Toyota stuff is a 1:10 (metric) taper if I recall things properly. You need to use the right taper (pitch) with steering parts.
Pipe is not really the best thing to make tie rods from, but does work and is very inexpensive.
The tie rod ends for the 80 series and 60 series (23mm vs 21mm on the 40 series) and also have the larger taper (but same taper angle) than the 40s (as well as the later mini-trucks, but they use the 21mm threads).
There is really nothing wrong with the 21mm units, but the 23mm are much more substantial. Depending on what steering you're setting up, you may be able to pick and choose a little what you are going to use.
~John
