tie rod/drag link
Buckley, WA
Ok i'm going to be replacing my tie rod and drag link aswell as new ends.
I've search and just want to make sure that the only options for a tie rod and drag link is OEM, Bud Built and Slee.
Those are the only ones I've found.... I was told that Marlin did some for the 80 but I couldn't find any on his site and when I called no one answered.
I just want to make sure that those are my only options before I decide.
Reinforced/modified stock?
I went with Slee's, think it was cheaper and ordered a few other things as well.
If I were to replace my bent drag link I would go with the cheaper of Man-a-Fre or Slee.
My tie rod wasn't bent (it is protected well behind the axle housing) but the threads were frozen. I replaced it with an OEM equivalent and used anti-seize liberally on the new OEM tie rod ends. I spent about $140.
I would go with the slee ones.
I forgot about man a free... i'll check out their site also.... so far it looks like bud built is the cheapest and they seem to make quality products so I think I might be going with them
Bud built sounds good too.
Just got both from Slee, like everything else, I have been pleased with the quality and service.
Plus I think that it simplifies things if you stick with one provider/vendor.
Since I have a Slee lift etc it made my choice pretty easy.
Oh and btw.
According to my dealer, who had to reorder the rt side drag lnk end 3 times, the Toyota parts catalog has an error on the drag link rt side part #, just make sure you are placing an order for 4 different part numbers if you order oem parts.
However, if you order from CDan, he will likely know the part numbers without looking at the parts catalog and the you will have no worries!!!!!!!!!!
