Ticking sound with acceleration.
PNW
I’ve had my 100 series for a couple weeks now. Had the timing belt and water pump done almost immediately and I just installed a new radiator and replaced the drivers door lock actuator motor over the weekend.
There is a ticking from the engine bay with acceleration and after reading some post about the spark plugs backing out, I checked the torque on all of them today. All seemed to be torqued to 17 ft lbs, so I’m ruling that out.
My next suspicion is the ticking is coming from a cracked manifold. Curious what others thoughts are and if it is the manifold, is this something I should address right away, or can I put it off for a few months?
Likely a cracked exhaust manifold, it's fairly common. There's no emergency to fix. Lots of threads here about it.
Thank you, kinda what I figured. The threads on here have been amazing. Most of the knowledge I have about the 100 comes from Mud.
does the ticking sound get louder or faster when you drive (rotating part)? Or you hear it when you drive through road imperfections like a rattle (loose/unfastened part)? Or you can only hear it when you stop (exhaust, typically a crack/fracture in one or both headers)?
No, it is only noticeable when I’m on the accelerator and no increase in speed or volume. Definitely not a rattle.
Interesting. Sounds like it’s engine load-related, could be the headers. Try a smoke machine and hook it up in the exhaust outlet to see if it’s indeed an exhaust system leak.
That’s not a bad idea.
Probably your manifold/s cracked. Depends how bad the leak is, I wouldn't want to smell exhaust in the cab. Mine have been ticking for 5 years now.
No exhaust smell in the cab.
