Thud on acceleration
Beaverton, Oregon
I've casually searched for something similar, but haven't found anything like this.
I have a strange, soft thudding noise when I accelerate from a stop. Sometimes. It started quite a while ago, but was very intermittent and I couldn't figure out how to repeat it. As it's gotten more noticeable, I can pinpoint it to the take-off after a reasonably hard stop. If I coast slowly to a stop, or even better, a not-quite stop, no thud on acceleration. If I stop with any gusto, I get a thud. It is a really soft, deep thud that you can feel as much as hear and it usually happens within the first few feet of acceleration.
It almost feels like something is un-binding from the stop. Calipers appear tight, steering is snug, and everything else looks as it should from a cursory examination. A few times lately, I can feel it binding up as I stop, making the same thud feeling/noise as the truck stops. Then, when I pull away, it sort of unbinds and makes the noise/feeling again.
I'm stumped.
FWIW, OME Mediums with OME caster bushings.
no help here, but funny, my cruiser has the same symptoms. it did it when i bought it, put OME 2.5 med lift and still does it. new u joints and rebuilt driveshafts about 1000 miles ago. new brake pads and turned rotors at same time.brakes all seemed tight on inspection( but do make clicking sound when pedal first depressed, have not re-inspected) back to the clunk, though not violent, is noticable on take off.
Lube your front and rear propeller shaft (drive shaft) slip yoke. Any good grease will do; moly or HD.
-B-
-B-
X2, but don't pump it full of grease. It's best to drop the shaft, pull the two pieces apart, clean out the old nasty caked grease (if there is any), and regrease the splines by hand so it moves nice and freely when reassembled.
x3 here. When I bought mine it did what you are describing when it came to a stop and when it started from a stop. I found great info on this forum about lubing the splines, and I couldn't believe the clunking was from this -- but it was! Also, I researched the greases, and it seems that grease with moly additives are usually spec'd for this application. Toyota does not spec the moly grease, but I used it, and I'm loving the smooth operation!
Thanks to Beowulf and MUD for the info that helped me.
I had a similar noise, researched it,... it seems it's the nature of the beast!. it is rare, but noticeable.
Joeb.
I have the same problem. It is the nature of the Beast. Even when you pull the driveshafts apart, clean and regrease the splines, the clunk will still be there. I traced it back to the t-case. With the driveshafts disconnected, I can feel a considerable amount of play by turning the yokes at the transfer case. Worn gears? I am curious to know if there is a way to adjust the spacing between gears in the t-case?
Read his problem description carefully. He is not describing the characteristic Land Cruiser clunk. I believe he is describing an issue with lubrication in the DS slip yoke; primarily the rear DS. I could be wrong. :flipoff2:
-B-
Yeah, definitely not a clunk. I mean, I have that too, but I'm past worrying about it. Seems to be the typical clunk. This is different. Very soft thud. I need to grease things up before our next run anyway. I'm about due. That's probably it. I<3IH8MUD. Thanks.
I have it as well and am thinking it's the soft lines going to the calipers causing a little stick. These lines are more than 10 years old and will swell over time. That swelling will hamper the release of pressure at the caliper.
This thunk feels brake related to me too. Will address the DS situation first and see what transpires.
I thought we were trying to help eachother out, but I guess it's all about you... :flipoff2:
Actually I was focused on the OP's question and didn't realize you had a turning issue as well.
You know you have a bad drive shaft so it's hard not to assume that is your problem. I did resolve some of my problems by replacing a bolt that wasn't up to par which was part of a suspension piece I bought from Man-a-fre.
