Sometime back before the holidays I began hearing an odd knocking noise from the FJ40. It would come and go but gradually became a bit more noticeable. I wasn't driving the 40 much so the noise was not something I gave much thought to, until yesterday. I drove the Cruiser to work and on the way home began to experience rough clutch engagment (2F, 4 speed, blah, blah). But the rough engagement went away
, only to be replaced by no disengagement :
: Clutch pedal pressure has remained firm. Starting in gear and clutchless shifting are techniques everyone who drives a manual trannied Cruiser should learn.
I won't have time to pull the inspection cover until this weekend but I have been considering what I may find. If this is a small problem I'm thinking that the clips have somehow worked loose allowing the throwout bearing to float free of the clutch fork. But what I am expecting is that the TO bearing became frozen and in riding against the clutch caused the small clips to be ripped off.
Any thoughts?
: Clutch pedal pressure has remained firm. Starting in gear and clutchless shifting are techniques everyone who drives a manual trannied Cruiser should learn.I won't have time to pull the inspection cover until this weekend but I have been considering what I may find. If this is a small problem I'm thinking that the clips have somehow worked loose allowing the throwout bearing to float free of the clutch fork. But what I am expecting is that the TO bearing became frozen and in riding against the clutch caused the small clips to be ripped off.
Any thoughts?
