Throttle Positioner -- Emissions
Mr. Toad
20 Year 15 Year 10 Year
My throttle positioner seems to work only randomly. Anyone have any good info on diagnostics? Emissions manual scans?
Here's What I Know: It's a 1975 2F with federal emissions. The vacuum switching valve (VSV) works properly when energized/de-energized. The throttle positioner (TP) itself works fine with appropriate vacuum. High idle is set to 1200 rpm, so I know when the TP is operating. Excellent electrical continuity from the VSV back to the emissions control computer (ECC). Excellent continuity from the ECC back to the speedo head, which houses the speed sensor.
The speed sensor is odd. Usually at 0 m.p.h. it reads open loop across the two spades. However, sometimes it reads about 10-20 Ohms at 0 m.p.h. A twitch of the speedo cable usually sends it back to open loop. Somewhere between 5-8 m.p.h. the resistance of the speed sensor goes reliably to 0.6 M-Ohms and stays there up to about 35 m.p.h. (That's the fastest my cordless drill will spin my speedo). Slow it back down and it goes back to open loop (5-8 m.p.h.) and then sometimes to 10-20 Ohms at 0 m.p.h. like I said earlier.
I'd really like this to work properly, since this circuit also de-pressurizes the fuel tank. Lower tank pressure means less chance of fuel odor inside the cabin.
It sounds like a wonky speed sensor, since you can jiggle it and make it work. The other weak link is the chassis plug for the engine control computer. Vibration tends to break the PC trace at the solder joint, so resoldering it can fix it.
Thanks Pin_Head--I didn't know about that issue. I'll check card to plug.
But otherwise, anyone know if Open Loop/0.6M-Ohms is correct operation for the speed sensor?
I am having some trouble understanding your description of the operation of the speed sensor, but basically it is a speed sensitive switch. Above about 10 MPH it switches which tells the computer to energize the VSV so that manifold vacuum will pull the TP off the idle cam. The resistance should go from 0 to infinite and back, but it is not continuously variable.
Right. For clarity here's what my speed sensor is doing (when it's not being wonky):
At 0 to let's say 7 m.p.h., resistance is infinite (open loop). As soon as the speedo hits 7 m.p.h., the resistance decreases to 0.6 M_Ohms (as in million) and stays at 0.6 M_Ohm as fast as I can make my speedo head turn (about 35 m.p.h.). When the speed drops below 7 m.p.h. again, the resistance increases to infinite.​
7 m.p.h. is OK for a 1975 federal speed sensor to trigger the throttle positioner, but 0.6 M_Ohms is a buttload of resistance. Like you, I was thinking it would drop down to something like 0. If 0.6 M_Ohms is the spec for the speed sensor, however, I'm OK with it.
Note: the speed sensor is supposed to trigger another ECC operation just above 40 mph, so maybe different levels of resistance in the speed sensor activate different functions.
Sorry if that wasn't so clear before. It's always confusing jumping into someone else's problem. Thanks again.
The Wrap-Up
Turns out the computer was bad. All of the solder joints were OK, but the printed circuit board was corroded really badly in a couple of places. Thanks to samsr for hooking up an Ih8Mud-er in need.
The speed sensor signal is a pulse. That's what I was taking to be a bad signal. It was fine.
So now I've got vacuum on my fuel system when I'm supposed to have it, and my throttle positioner functions again. No more stink (from unburnt hydrocarbons) when I decelerate in gear.
For future 'Mud searchers, here's how to test the speed sensor: Tap into the signal wire from the speed sensor at the computer plug harness using the (+) lead from your ohm-meter. Ground the (-) lead. Lift one rear wheel and turn it slowly with the tranny in neutral. (Chock it first, kids) If the speed sensor is working OK, you'll see the needle (or numeric display) pulse regularly. That's it.
There's also a port in the emissions test plug that's supposed to be the same as tapping into the signal wire. Didn't work for me.​
