Hi guys, I'm chasing a problem with starting, it cranks and idles for a second then dies.
While doing the troubleshooting I looked at throttle body and noticed that with ignition on and gas pedal is pressed, the throttle plate does not open, it should be opened correct? My truck is an 98 so it has the cable pulled accelerator pedal position sensor .
I followed the FSM throttle trouble shoot and see that the throttle control motor clutch resistance is at 7.2 ohms, the the FSM spec is 4.2-5.2 Ohms (so this is out of spec). The throttle position sensor is measured at in spec as in the FSM. The accelerator pedal position sensor is measured to be in spec.
Can you share more troubleshooting tip on this?
Thanks.
Thanks.
