Threading help
Bay Area California
The threads on the interior of this are just a little bit messed up at the start - it’s not crazy .. but here’s the deal I just got a new union for my banjo bolt on my carb which attaches to this and I don’t wanna mess it’s threads up screwing it on. Will I?
should I force it through. I’m not privy to ordering a new line if I can help it....
If you carefully cut off the compression fitting, you can slide the nut off, clean it up, and reinstall with a new compression fitting.
5/16” Home Depot compression fitting should work just fine.
