thread specs. please
North Cadillac
This is kinda embarassing, but i have waaaay too many threaded bolt holes that are either cross threaded or stripped. Only two are my fault :o One being the threads on the front output of the tcase. I stripped it by sliding the DC driveshaft on and off and on and off making sure it was making racket ect.....
I think Cdan said it was 1x10mm...i think?
The other that is my fault is the rear driverside seat. the back bolt. I got in a hurry one night while camping trying to take the seat out so i could sleep and ended up stripping that bolt out. Fawk!
The others are the front and rear frame bolts that mount either a tow hitch (in the rear on the frame rail) and the front to mount the ARB. I realized why there was no tow hook......the friggin bolt hole is stripped out. :mad: The PO did these so it's not my fault. But still, i need to get these fixed so i can properly mount my bull bar and so when i get my rear bumper it will properly mount.
So if someone could give me the thread specs on these bolts i would greatly appreciate it.
If they are striped out are you going to the next size and tap em out? For the frame you could use a 3/8 coarse thread instead of the metric and use a tap and maintain the same size hole. These sizes are from the FSM, the ones in the frame are 8T bolts in 8, 10 and 12mm with a torque of 22 to 24 ft. lbs. and the pitch is 1.25. If I recall the side and bottom bolts for the ARB are 10mm and the top are 12MM. The bottoms are 2 inchers to clear the spacer for the ARB and still be able to use the tow rings. Not much help is it.
For a 1997
Front and rear frame – top and bottom 12 X 1.25
Side of frame front 10 X 1.25
Rear of DS seat to floor pan 10 X 1.25
Bill
Edit to say threads on the transfer case REAR flange are 10 X 1. Front flange may be the same?
Edit to correct as per CDan’s post #7. Front flange stud is 10 X 1, not REAR flange.
Rookie and Beno, you guys are exactly right acording to Cdan. That's why i want to put a thread chaser on them. They are not super bad, but they really need some attention.
Thanks a ton Bill. I'll take that info to the mechanic to see if he can make that work again. I hope i don't have to go a size larger.
The 80 series front is 10x1.0 and the rear is 11x1.0.
Drive shaft fasteners, the others are 1.25 pitch.
umm....hmmmm... what's....ummmm pitch? :o
and is that something that's important when picking the correct thread chaser or tapper?
Pitch is the number of threads per unit of measure.
IE a 1/2x16 (inch) bolt has 16 threads per inch.
A metric 1.25 is one thread per 1.25 mm and a 1.0 is one thread per 1.0 mm (finer than the 1.25).
D-
